Thread: cya 160-180 dilution method
    Jul 2016
    Bear/DElaware
    6
    Drained about 30% of pool and refilled. Should I just use bleach and no pucks. Is there a good shock to use. I have plenty of pucks but i believe that got me in this situation.Please send help. water is still crystal clear but I cannot lower my cya level.I have plenty of pucks and 2#s of shock left, I would like to make sure I purchase the correct chemicals to get out of this situation.
    Thanks
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    455
    Re: cya 160-180 dilution method
    there is a place up top of this page that says "Pool School" Hit it and read.
    You are going to have to get yourself a proper test kit to be able to get things under control.
    If your water started with 160-180 CYA, and you drained 1/3 of your water, that would bring you down to 107-120 ... still a bit too high.
    Any of the pucks, or the shock has CYA in it.... keep them handy for when you get your pool under control, and are going on vacation, or otherwise can't be there to dose it with chlorine (bleach).
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
