Thread: water safe to swim?
    Jul 2016
    Saint Joseph, MO
    45
    water safe to swim?
    Quote Originally Posted by atttech-2 View Post
    As you may be aware we don't trust pool store test results. For us to give a recommendation we trust you would need to post results from one of the recommended test kits. That being said if I were to believe those numbers then NO it is not safe to swim you need some CYA for the FC to bond to, 20 to 30 ppm for it to be safe.
    I am new here, and I keep reading "not safe to swim" with bad water results. What exactly does that mean? I'm in Missouri and we swim in rivers and lakes. Is this pool water less safe than a river or lake? Thanks so much - I'm trying to understand.
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: water safe to swim?
    Lakes and rivers have millions of gallons of water. People still contract diseases from time to time in lakes and rivers. Algae is fine. We don't put chlorine in the water to kill algae. The primary purpose of chlorine in pools is to kill bacteria, viruses and pathogens to prevent person to person disease transmission. Killing algae is just a side benefit.
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by pooldv View Post
    Thank you for making this a fresh post (apologies for tagging another thread). So, water gets hazardous quickly since the pool is a (very) small, confined body of water.
    I totally get it now. Thanks again.
    CHAD
    Sand 200 lbs
    Taylor K2006
    Jul 2015
    Central Valley CA
    1,109
    Also just a few ppm of chlorine and 0 CYA has many times higher FC than a SLAM level of a pool with the proper FC/CYA ratio because the chlorine has nothing to bond to. From the posts I have read I do not see a consus on the effects of swimming in water with that much FC but why take the risk when balancing the FC/CYA ratio is simple given a proper test kit. If you take a look at post #11 in THIS thread chem geek talks about the ratios he has mentioned it in other posts too this was just the first I found when searching.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Rivers and lakes have an exchange of water taking place. Its not the same water in the same place day in and day out like a pool. In a pool filtration and sanitation take the place of natural water exchange from springs and rivers. Filtration alone will not keep a pool sanitary.
    Love TFP? Become a
    TFP Supporter!
