Thread: how to floc using robotic vacuum
    Jul 2016
    Gainesville, FL
    126
    hey guys. Great forum. Just got done killing algae and pool is cloudy- I know floc is not recommended but I have a party coming up and need to clear up fast. I researched floc and it seems you need to turn filter to waste and the use vacuum to pull debris and dump it outside- however I have an Aquabot that does not hook to the circulation system. do I just let the water sit, and then put the Aquabot to work (leave the filter off)? or do I need to have a suction side vacuum to work in conjunction with filter?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: how to floc using robotic vacuum
    The method you suggest should be fine.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I'm a less confident in the aquabot if you're using a vac-to-waste floc product -- it could just cloud up and dissipate the floc, making a mess, getting it into your filter and leaving slimy bits all over that will just reform... based on a recent experiment.
    BTW, I don't generally recommend using floc either, but recently had used a floc-level volume of lanthanum chloride so I have in practice actually experienced its behavior
    The best way to remove floc is to vacuum to waste manually, very slowly to not redistribute/cloud it up, using the old-school manual pool vac and hose that attaches to the skimmer. If you have a party coming up, you really want to vacuum it completely to waste. Those manual hoses/heads for the skimmer are pretty cheap. In your shoes I'd pick one up.
    If you used something like Leslie's Alum, which is a vac-to-waste type, I wouldn't try to short cut the removal. It really needs to go to waste, but the robot action may keep breaking it up instead.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jul 2016
    Gainesville, FL
    126
    Quote Originally Posted by Swampwoman View Post
    that makes sense- the return water coming out of the robot at high speed would probably steer up the sediment around it.
