Thread: Not sure what chemical is missing "Leaf leaves stains at bottom of pool"
    May 2016
    Murrieta/CA
    28
    Good evening,
    I am hoping someone might be able to help me figure out what I am doing wrong. We have 10000 gallon plaster pool. We just drained it 2 weeks ago and acid washed it and refilled it. Been getting the chemicals back in order. Tonights results are listed blown. We are noticing that the bottom of our pool is being stained by leaf's that get blown into our pool.
    What are we doing wrong or how can we stop this from happening? The pool runs for 5 hours a day right now (single speed pump, currently have a variable speed pump on order) and I also throw in an electric cleaner over other day in the pool. Our filter is a Hayward DE 4800
    I have added some soda ash to bring up the PH, will test again in the morning.
    I know I need to increase my Calcium and picking up the chemical tomorrow.
    any other suggestions?
    Chlorine (FC) pmm 3ppm/5ppm
    PH 7.2/7.5 ppm
    Total Alkalinity (TA) ppm 170 ppm
    Calcium/Hardness( TH) ppm 175 ppm
    Cyanuric Acid (CYA) ppm Not present
    Thanks
    Scott
    Pool Rectangle with attached Spa (approx. 8000 gal, depths 4 feet and 5-1/2 feet), Pump - Hayward Super II, Filter - Hayward Micro Filter DE Model 4800.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Not sure what chemical is missing "Leaf leaves stains at bottom of pool"
    The only way to stop leaves from staining the bottom of the pool is not to let them sit there. Chlorine lifts organic stains. You can rub them with a trichlor puck or raise FC up toward shock level for your CYA, FC/CYA Chart, and brush daily until they lift.
    May 2016
    Murrieta/CA
    28
    Quote Originally Posted by pooldv View Post
    Thanks Pooldv I will have to start scrubbing
