Thread: Drain & refill mid season, don't want to lose again
    Jul 2016
    Saint Joseph, MO
    45
    Yes, the green came fast and furious, and family wanted clear water now. I found out that I can drain and refill in just under 24h. Before draining, I cleaned out the filter sand with the hose. I believe the hollow ladder steps with holes in them are probably the algae headquarters. Those will now see regular attention until we decide on a replacement.
    So, now I am following TFP directions, but need a little help because the test kit won't arrive for a day or two. In the meantime, all I have are test strips. So the pool was drained to about 4" deep, and I started refilling. At that time, I dumped in 1 gal of 12.5% chlorine and a sock with 1.75# of CYA (chart said 15,000 gallons need about 4# CYA to get up near 50) A couple of hours ago the pump could start again, and added 2 cups cellulose. After 20m of filtration I tested the water and the FC was at or above 10, the CYA was under 30, and the PH was 7.6-7.8, TA was OK. I only had about another pound of CYA, so I crushed that in a sock at the return jet. We swam for a bit in the freezing water (92 degrees outside though).
    I just tested the water again and FC 10+ with the CYA very close to the 30-50 color, slightly fainter... perhaps 25? But need to check in the morning. Question: what else do I do tonight? She's not crystal clear since there was still some of the old green water, so probably risk of turning again?
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Drain & refill mid season, don't want to lose again
    Hi there
    Without a good test kit you are kind of flying blind but it sounds like your calculations with pool math are good. If it's still cloudy, I'd just leave my pump running and brush. Do you have an eta on a test kit? Hopefully TF-100 or Taylor k2006?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by AimeeH View Post
    Hi there
    Taylor K2006 will be here tomorrow or the next day for sure. I double checked poolmath and 15000 gal going to CYA 40 requires 5#. I am still going to wait for a reliable test before adding more, don't you think?
    CHAD
    Sand 200 lbs
    Taylor K2006
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    That's the safer thing to do. Especially since you just drained. You don't want to have to do that again, I'm sure.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    I was in the same boat prior to the test kit showing up... Try to keep your FC in the 9 area just so your PH results aren't skewed... That will also help kill off any algae issues until you are ready to slam. Be gradual with your CYA additions!! if you over shoot, youll be using more chorline everyday and if you want it to lower you have to drain and fill... target 30 so you have room for error...if you overshoot a little, target 40 and youll be golden. Once your CYA is in that range, your FC is hovering around 9, check PH... Add Muratic acid to drop your PH to 7-7.2 then start your slam
    Also check your math... You say you have 24' above ground... Round? How deep? I have a 24' round 48" and it holds 13500 gal.. changes potential additions drastically
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jul 2016
    Saint Joseph, MO
    45
    Just unwrapped the K2006, since we are literally UPS's last stop of the day. Test results:
    FC 10ppm
    CYA 35
    CC 1ppm
    PH 7.4
    TA 150
    CH 130
    We didn't swim today (at the lake), and the water is not clear, and has little pockets of debris in the liner wrinkles. I'll sweep here in a bit. I have about 4 gallons of 12.5% chlorine on hand, but I'd like to use up the remaining HTH trichlor tabs if possible.
    So, where do I go from here to get this pool trouble free?
    **Signature edited
    CHAD
    Sand 200 lbs
    Taylor K2006
