Results 1 to 7 of 7
Thread: Brown walls dirt? Algae?
    Jun 2010
    Central Indiana
    92
    I use the BBB method and my water always looks great and my chlorine levels are good but the walls on a little over half my poo(24' round) is always covers with brown stuff. I'm assuming it's dirt and grime and not algae but I don't know any more. It is all over the wall in the direction opposite whichever the return eyeball is pointing. If I brush the walls it comes off and goes into a cloud of circulation until it filters out or settles. I keep my free chlorine between 2-6 and never have any cc on the test (never turns back to pink). So is this normal? Is it dirt or possibly algae? How do I fix it?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Re: Brown walls dirt? Algae?
    I'm going to step up and ask the proverbial question. Can you post some accurate recent test results?
    A picture maybe as well?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Yes, need to know your CYA level to know if your FC is too low. The best thing to do is an Overnight Chlorine Loss Test to see if something is brewing. FC of 2 is a little too low for comfort for me even if your CYA is 30. FC/CYA Chart
    Jun 2010
    Central Indiana
    92
    Chlorine was 2 before adding more tonight
    Combined chlorine 0
    Cya is 30
    Ph 7.8
    Going to raise to slam levels and do overnight loss test tonight.
    Jun 2010
    Central Indiana
    92
    It's 13.5 free chlorine tonight. Since I am at slam level should I still only expect it to drop 1ppm or less over night of will it drop more since starting level is higher
    DFW, TX
    24,516
    Yes, 1 or less is a pass. Lots of people do OCLT during SLAM.
    Jun 2010
    Central Indiana
    92
    27 drops last night 24 today. Pool school says accuracy is plus of minus 10% when using more than 10 drops so would this be considered a pass or fail?
