Thread: Pool decks: Pavers, Concrete or Other?
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    So, as I approach the project of replacing my pool deck I'm unsure how one would go about placing pavers on top of the required bonding grid. My experience with pavers has been to set them on a sand bed, tamp then fill with polymeric sand. Is it permissible or effective to have the grid buried in the sand bed that the pavers sit on?
    With concrete it's pretty straight forward as the concrete would flow into and around the grid, thus encasing it in the concrete itself. So, not a lot of questions to that.
    Any other ideas for a pool deck that I might should consider as alternatives to those two options?
    Polar Pools, 19' x 39' Vinyl Lined IG, 3' to 9' deep, 33,300 Gallons?
    Pentair Intelliflo VS, Hayward Sand Filter Model # S244T, Compupool SWG, Heliocol Solar Heating
    K-2006 test kit, 1766 Salt Test Kit , Taylor SpeedStir
    Built in 2009, Salt Lake City, UT.
    Feb 2016
    Atlanta, GA
    145
    Re: Pool decks: Pavers, Concrete or Other?
    I've been told a grid isn't required by the code if you do pavers. Simply a loop of copper wire around and attached to the pool at several points and with several grounding rods.
    I think it depends on your local building department what they require.
    Nov 2015
    Woodland Hills, CA
    176
    I tied the shell bonding wires to a loop of #10 wire one foot away from the edge of the pool around the entire perimeter of the pool on top of the of the base material before the paver were set or base sand was dumped. It was tied in to the ground going to the equipment pad. I also sunk a copper ground rod at the equipment pad and tied the "loop" to the rod as a belt and suspenders.
    Extra grounds dont hurt... generally. No way would I not have something around the pool if I were you. I was not sure - so I called my AHJ and we talked about what he wanted before I got too far down the road. He asked for a loop around the pool.
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    Thanks for the input so far..
    I definitely want a full grid and would even consider taking it the full 6' wide (width of the deck) instead of the minimum 3' because I know that I have stray voltage in the area and want the best possible mitigation in place. I'm just having a very difficult time finding a concrete contractor that will come bid on the new deck install so I now need to consider DIY methods which has brought me to the idea pf pavers. I'd hoped I could lay the grid down, then bury it in the sand bed underneath the pavers, just not sure what that would do to the functionality of the equipotential grid
