Results 1 to 14 of 14
Thread: My algae battle progress (or, "want to see a SLAM?")
    entendu's Avatar
    May 2016
    Central Coast, CA
    23
    Getting ready to move into the new house and trying to get the pool ready for the day we land there. Spent some time over the weekend checking out the current state of the pool. Previous owners had a "pool guy" who was there the day before skimming... but apparently not doing much else. Lots of debris, lots of algae. First thing, the starting test results:
    Day 0:
    FC: 0
    CC: 1.5
    TA: Acceptable (didn't write it down)
    pH: 8
    CYA: <30 (black dot still visible)
    Lots of yellow on the sides and bottom. Scooped the pool, set up the new robot, and did LOTS of brushing. Threw in the leftover shock packets (old, wet) which may have done more harm than good. This is one day in:
    Not awful, but really cloudy. You can see the accent tiles disappear towards the deep end. I actually could not see the drain
    That means one thing - SLAM TIME
    Bought 10% bleach, some MA, and CYA for after the SLAM. Aiming for FC of ~12 cause of the low CYA.
    Day 1:
    Added 1/2 gal MA, 6 gal 10% chlorine. End of day readings:
    FC: 12
    CC: 0.5
    pH: 7.7
    Day 2:
    Lost my notes. Added some chlorine.
    Yesterday (day 3):
    FC: 8.5
    CC: 0.5
    pH: 7.5
    Added 2 gallons of 10%. Noted lots of particulates still, increased pump time from 5 hrs/day to 8 hrs.
    Today (day 4):
    FC: 7.5
    CC: 0.5
    pH: 7.7
    Added 2 gallons of 10%, 0.5 gal MA. Looking MUCH clearer, I think we turned the corner:
    Questions:
    I'm sure I have plenty of FC loss from sunlight with such a low CYA, but I don't want to pump CYA until SLAM is done. Sound reasonable? My plan is to just keep pumping chlorine in until the water's clear and CC is 0. Probably can't do an overnite test since I don't live there yet.
    I have an inline tab feeder, I'm not clear on what to do with it. Throw it away and use liquid only? Use non-stabilized tabs? Previous owner left a big bucket of stabilized tabs.
    Any other recommendations? Just keep on truckin?
    20'x40' IGP, plaster, 40k gal. Full sun.
    Pentair Triton II sand filter, 2 hp single speed pump, Triton minimax plus 400 heater.
    k-2006 test kit, Polaris 9550 Sport robot
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: My algae battle progress (or, "want to see a SLAM?")
    You need some CYA. Otherwise you lose your whole battle to the sun. Shoot for 20 if you want to be conservative.
    Save the tabs for vacation or organic stains.
    Otherwise sounds like you've got a good handle on things.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Smile Re: My algae battle progress (or, "want to see a SLAM?")
    There only stabilized tabs aka trichlor. cal hypo tabs are for commercial use only and are an explsion hazard in trichlor tab chlorinators, from what I've read. Use bleach/ liquid chlorine! That's the TFP way! Beautiful pool!:
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    entendu's Avatar
    May 2016
    Central Coast, CA
    23
    Quote Originally Posted by mulia View Post
    Thanks! Excited to swim. That's what I needed to know about chlorine too
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Also......looking at your numbers and thought I'd add that during SLAM you really don't "have" to test PH (save your reagents). And the PH test is generally considered skewed when FC is above 10.
    Your pool is looking great
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Oh you only THINK it looks good now! Wait until you see it looking like a jewel or you look out and think the water is gone because it is SO clear!
    You are on the right track. Keep on keeping on and you will only have to move the boxes then jump in the pool to cool off!
    Kim
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Very nice set up!
    I know you aren't there yet but if you could run your filter 24/7, it will help clear up more quickly.
    Welcome!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    entendu's Avatar
    May 2016
    Central Coast, CA
    23
    Day 5:
    FC: 8.5
    CC: 0.5
    CYA: dot visible all the way
    Added 4 gallons 10%, 5 lbs CYA. Making double-sure we're above mustard shock level. Instructions said to broadcast CYA in the deep end, which was interesting. Pump time increased to 24 hrs.
    Jul 2012
    Tallahassee, FL
    30,580
    uh oh.........we put the CYA in a sock (like you wear) and hang it in front of the return and squeeze it every once in a while to help it dissolve.
    Are you home to go out and brush and mix up the CYA in your pool? I would hate for it to mess up your plaster. At least it is not a vinyl liner. Maybe thrown you robot in there to get it off of the floor. Just don't back wash for a couple/few days to allow it to dissolve and mix in good from the sand.
    Kim (ONE day the pool companies will "fix" their directions)
    entendu's Avatar
    May 2016
    Central Coast, CA
    23
    Days 6-8:
    Spent day 6 at FC=15 shock level. CC went to 0 on day 7, stopped adding chlorine. Brushed CYA powder around, it dissolved quickly. Perhaps it got sucked up by the main drain?
    Day 9:
    FC=6
    CC=0
    pH=7.7
    TA=200
    CYA=33-34
    Pool is now sparkling. TA is high which I think is accounting for the pH drifting up, seem like +0.05 every day or so. CYA obviously need to go up because of the full sun loss. OCLT was good but I lose loads of FC during the day. I'll deal with that once I'm moved in -- for now, things are looking GREAT! Thanks, TFP!
    If anyone wonders how long a slam takes, send them here. 9 days start to finish. I think some less-knowledgable poolgoers would even call my "before" pictures acceptable.
    Jul 2012
    Tallahassee, FL
    30,580
    We will work on tweaking your levels when you move it. It is easy but you need to be able to be there a couple/few times during the day to test and adjust.
    That looks awesome! So clear! Wait until you look out at the water and wonder where it when did that one time here!
    Kim
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Quote Originally Posted by entendu View Post
    ............ Noted lots of particulates still, increased pump time from 5 hrs/day to 8 hrs..................
    Pool is looking great!
    One thing I noticed is that you are only running the pump 8 hrs. During a SLAM it is recommended to run the pump/filter 24/7 to keep the water well mixed and circulated.
    Also, seeing that you were only testing/dosing once a day I would have initially raised my CYA to a solid 30-40ppm to help protect it from the sun, especially if you are in Southern CA (your location doesn't specify & CA is a big state).
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    entendu's Avatar
    May 2016
    Central Coast, CA
    23
    Thanks for the good feedback, yeah I'm looking forward to moving in so I've got full control over testing & nursing it up to perfect levels. Right now my parents are stopping by once a day and they text me the levels they get with my k-2006 and I text them back what to do. I showed them how to use the test kit, plus they have a spa and we used to have a pool many years ago so some of the muscle memory is there It's been a team process for sure but I'm super proud of what we've been able to accomplish with the help of TFP and text messages!
    Jul 2012
    Tallahassee, FL
    30,580
    You know you are our new "poster child" of what can be done even when conditions are not ideal (not living at the house). LOL
    Kim
