Thread: Why does the test tube get cloudy?
    Jul 2016
    Vineyard Haven
    2
    Hey ALL
    So I over see a pool at a YMCA. Where we test the pool at least 4 times a day. However after only a month of use the tube that comes in the testing kit gets cloudy.(I am talking about the walls of the actual tube, not the water). It is a Taylor kit K2006C.
    Is there something that I can do to prevent this?
    Thanks!
    Jun 2014
    15,096
    Re: Why does the test tube get cloudy?
    Just clean the tube inside with a bleach solution. It should be fine.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Its cause those reagents are real, live chemicals. For example the CYA reagent is melamine. Isn't that like plastic??? I dunno...?
    I've used vinegar or muriatic acid before to clean them out. Most days now I always grab a paper towel with the test kit and wipe them out before storing again. It helps.
    I only use the MA when I'm also putting it into the pool so I just pour a skosh in and let it sit then add it to the pool with the rest.
    Jul 2016
    Vineyard Haven
    2
    Thanks I will try that!
    Jul 2012
    Dallas, TX
    179
    Duuhnese
    Ditto what YippeeSkippy said about the paper towel mention. I read that tip on this forum a while back and since I've been wiping out the inside of the vial with a paper towel (after rinsing with tap water after testing), I haven't needed to do a Bleach or MA soak to clear the film inside the vial.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
