Thread: Pool psi
    Jun 2016
    Michigan
    50
    Pool psi
    The psi in my pool is always around 40-45 until I clean my cartridge filter then it drops to about 30 psi. I have to clean my filter every 2 days after doing so the water pumps out of the jets and into the skimmer at a much stronger rate. Any reason why it keeps raising so often? Thanks for the help.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool psi
    Chances are you have a bad gauge. 40-45 is pretty extreme. Does it go to zero when the pump is off?
    If your cartridge is old or your water is dirty, frequent cleaning may be the norm. Fill us in on some details about your pool and filter system.
    Jun 2016
    Michigan
    50
    Re: Pool psi
    The Guage seems fine, and it does go to 0 when the pools off. The pool is crystal clear and the filter itself can't be over 1-2 years old.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pool psi
    Sounds like an algae bloom to me. You can do the Overnight Chlorine Loss Test to see if there is some algae. If there is the SLAM to get rid of it. You will need an FAS/DPD chlorine test. If you don't have one I buy mine at TFTestkits.net. If you don't have a fantastic test kit then get the TF-100 instead.
    Jun 2016
    Michigan
    50
    Re: Pool psi
    I took care of my algae problem and it's still occurring.
    DFW, TX
    24,502
    Re: Pool psi
    If your water is crystal clear and you pass the OCLT then it is probably time for a new set of cartridges. I prefer Pleatco, cost less, work better.
