Thread: How Long Does Aeration Take
    Jul 2008
    Seacoast, NH
    250
    My pH is 7.2 and TA is 70. Want to get pH up to 7.5.
    I've been aerating for an hour by having the 3 eye balls turned up. 2 are bubbling, 1 is throwing the water up in the air about 3 inches. There's been no change in pH. Am I expecting too much? How long would be a reasonable time to leave it before I test again?
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: How Long Does Aeration Take
    Give it a day, Or have a pool party with lots of splashing. if you got time and inclination you could make an aerator its a fountain that's turned down to aerate the water.
    Smoking hot pool water
    JoyfulNoise's Avatar
    May 2015
    13,213
    It will take a few days with your setup. As the TA gets lower (below 80ppm) it takes longer and longer for the pH to rise.
    Matt
