Thread: Calcium hardness
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Calcium hardness
    I'm in the middle of a slam.
    14FC
    1.5CC
    Ph 7.7
    TA 130
    CYA 50
    Calcium H 210
    should my Ca Hardness be higher with a gunite pool?
    thanks;
    lori
    20x40 25,000 gallon gunite w/attached spa caretaker system stayrite system 3 filters Hayward Lxi heater Taylor 2600 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Calcium hardness
    Yes, but don't do anything about that until after the SLAM.
    Here are our recommended levels: Pool School - Recommended Levels
    Jun 2014
    15,059
    It is true you are just under the minimum level for a non-SWG pool (250). As YS noted, not worth worrying about right now as maintaining your SLAM FC of "20" is most important. (Hint, hint ..... 20)
    Afterwards, it may not be earth-shattering if you have relatively hard water in your area and summer refills might increase that fairly quickly. In addition, your low CH is currently off-set by your pH and TA that are keeping the CSI elevated and plaster healthy on the CSI scale (Poolmath calculator) at about .28. So you're still in good shape right now. Happy SLAMMING!
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Ok thanks!
