Thread: Intex sand pool pump sf80110 timer
    Jul 2016
    Grimesland North Carolina
    2
    Unhappy Intex sand pool pump sf80110 timer
    Hi Yall I have an upgraded filter only a month old the intex sf 80110 and the timer worked only once! Since then Ive tried to reset it according to the instruction manual and it still keeps running! Ive tried several settings to no avail! Intex doesnt want to know anything without the reciept. Any ideas to try or any fixes are welcome.. thank you Pati
    Hi From North carolina I have an Intex above ground frame pool 15 ft trouble with timer
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Re: Intex sand pool pump sf80110 timer
    When you turn on the timer side of the switch, after setting the hours you want it to run, the pump starts and keeps running for that set time.You can not set it to come on 3 hours after you have turned it on, for instance. It runs immediately, then shuts off at your preset # of hours. If you know that, but it still will not shut off after running the preset time, and intex will not help, you could plug it into a outdoor timer and leave the pump switch on the "on" setting.Then it will come on & off on the new timer.
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
