Results 1 to 10 of 10
Thread: Slam questions;
    Jun 2016
    asheboro NC
    4
    Slam questions;
    Hi I've been in my slam process for 2 weeks, I can see the bottom in the 3ft and maybe 4 1/2 in the deep. My f is going between .5 and 2.1.. my cya is 30 and I've gone through 6 to 8 gallons of clorax a day... should I try to get the cya up? It is getting costly and I'm praying it will be clear soon. Any suggestions or help? Thanks
    20,000 gallon in ground, Hayward pump and Sand Filter. Chlorine pool, vinyl liner (old need replace soon)
    Jun 2014
    15,145
    Re: Slam questions;
    Hello and welcome to TFP! Can you confirm please which test kit you are using?
    For your SLAM to work properly, remember that with a CYA of 30, your FC "SLAM" level is"12". So you need to increase and keep the FC level at 12 as much as possible until you pass all 3 SLAM requirements (link below). Consistency in the FC is much better than spikes & dips in the FC level throughout the day. And for bleach, you can shop around for the best price. Just about any brand of bleach will work, including generic brands. Just make sure to never use any splashless or scented bleaches.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Slam questions;
    Welcome to TFP!
    If your FC is between 0.5 and 2.1 then it doesn't sound like you are following the SLAM process here, SLAM. Are you following all of the steps listed? How often? What are your latest test results?
    There is nothing more important than current valid test results. Here's what we need.
    FC - Free Chlorine
    CC - Combined Chlorine
    pH
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    Borates - (if you are using borates)
    Jun 2016
    asheboro NC
    4
    Re: Slam questions;
    Thank you, I was posting my fc after over night.. sorry.. I'm trying to get this right!
    Jun 2014
    15,145
    Re: Slam questions;
    Oh, so you're saying the .5 - 2.1 was your overnight loss perhaps? Well, still sounds like you need to continue the SLAM. But it does raise a question .. how are you testing your FC? You should be doing it like this:
    10 ML water sample with one heaping scoop of powder. Mix and count drops until clear, then divide that number by 2. Example: 24 drops = FC of 12.
    Jun 2016
    asheboro NC
    4
    Re: Slam questions;
    After adding the slam chlorine
    fc 16
    TA 140
    CH 130
    Cya 30
    PH 7.1 (was 7.6 when started slam process)
    Taylor 2600
    DFW, TX
    24,497
    Re: Slam questions;
    The PH test is not valid when FC is above 10 ppm. Please update your signature to show whether your pool is plaster, vinyl or fiberglass. Your CH might be too low.
    Jun 2014
    15,145
    Re: Slam questions;
    Good SLAM numbers. Slightly high on the FC (12), and I don't see your CC, but okay for now. An FC of 12 should be plenty to do the job, and you can always post CC some other time. No rush. Also make sure to review the SLAM page every day or so to ensure you're doing all the other tasks on there. Lastly, if you've not cleaned your filter in a while, you may consider doing a Deep Cleaning a Sand Filter as well.
    Jun 2016
    asheboro NC
    4
    Re: Slam questions;
    I have been only able to check and add 2 times per day, I'm trying to get to this more often now... thank you for your help! I've bought so much bleach in the past 2 weeks they can't keep in in stock! I'm afraid they think I'm using it for something "shady" LOL
    should I add chemical to make CH Higher? Pooldv?
    Jun 2014
    15,145
    Re: Slam questions;
    No need. With a vinyl pool you are good.
