Thread: Total Dissolved Solids (TDS)
    Jul 2016
    Colleyville/Texas
    1
    Leslie's Pool advised that I treat my 25000 G chlorine pool for exceptionally hiigh amount of Total Dissolved Solids?
    Any recommendations?
    Jun 2014
    15,283
    Re: Total Dissolved Solids (TDS)
    Hello and welcome to TFP! TDS - ignore their response .. and probably many others they give you. Stay away from the pool stores, they'll only give you bad advice. Test your own water with a TF-100 or Taylor K-2006C (link below). Spend some time reviewing the other links you see below in my signature and you'll be in much better shape.
    By the way ... here's a good discussion on TDS: What is TDS?
    Nice to have you with us.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    The best recommendation is to stop listening to them, spend a couple days looking around TFP...
    The #1 best money spent for you and your pool is a test kit, TDS has nothing to do other then tell you have much stuff is dissolved in your pool..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, my recommendation is to stop going to Leslies.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    TDS is a "scare tactic" sales model used by many pool stores. As many things both good and bad contribute to the TDS number it by itself is meaningless.
    Support the site
