Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Blue Streaks After Shocking!
    Jun 2016
    Vestavia Hills
    34
    Shocked Pool Last night and this morning there are blue streaks on bottom that brush will not remove!
    Any ideas?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Blue Streaks After Shocking!
    Vinyl, plaster or other?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    What type of "shock" did you use? It might have had metals in it. Here we like to use Pool School - SLAM - Shock Level And Maintain
    But first you need to read
    If possible, a picture can be extra helpful.
    Jun 2016
    Vestavia Hills
    34
    I used liquid bleach, and the pool is plaster.
    I used a decent amount of algaecide a few months ago but why would the staining just show up?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Welcome to the Forum!
    Please add your signature and if possible add some pictures of the areas. Please provide us a detailed description of the events that led up to the streaks and answers to some of the previous questions. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by Knighaw View Post
    Because some algaecide has copper in it. In a high chlorine environment, the copper will turn blueish-green (think the Statue of Liberty or an old penny).
    There's a good chance this blue streak is oxidized copper.
    Jun 2016
    Vestavia Hills
    34
    Thanks Mike-
    What do you recommend to test the copper level and remove it?
    Sorry the pool has been a bit cloudy and even shocking isnt getting rid of it 100%.
    Could this be from to copper as well?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Honestly. It's a bit controversial topic around here and I don't feel like getting attacked on an open forum. There's a member, SwampWoman (I think that's the exact username) on here who is very knowledgeable on metal removal. Her opinion is well respected. If I ever suspected a metal problem in my pool, I would def reach out to her.
    First is to actually determine Copper is the culprit. Do you know the exact brand algaecide you used? So we can check the ingredients. Then I would get a water sample to get tested fro any metals. Not tested by a pool store, but by a real water treatment place. Like a company that sells and services water softeners.
    Jun 2016
    Vestavia Hills
    34
    Thanks, I will do so.
    Can copper cause water cloudiness as well?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    No, it won't cause cloudiness. Generally organics, such as algae cause it to be cloudy. Do you have one of the recommended test kits to give us a full set of test readings?
    Jun 2016
    Vestavia Hills
    34
    Yes, I will go take readings now!
    Jun 2016
    Vestavia Hills
    34
    Fc: 10
    ph: 7.6
    ta: 200
    cya: 60
    ch: 60
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Please add your pool info to your signature as shown here, Pool School - Read This Before You Post.
    You have a lot going on in your pool and the information needs to be visible on each post so we don't have to dig through the thread to find it.
    Jun 2016
    Vestavia Hills
    34
    Updated
    19K gal, IG Plaster, 1 1/2 HP Hayward pump, Hayward S200 Sand Filter, Creepy Crawly, TF100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Any easy way to tell if it is metal is to rub a vitamin C tablet on it for a few minutes. That will lighten the area you rub if the stain is metal.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I think OP did the Vitamin C test already. From what I understand it didn't lift immediately. Turned real dark at first and then after some time, the stain lifted. Every time I do a C test, I get same results. Freaks me out that initially it looks worse before it gets better.
    Jun 2014
    15,233
    A stain turning darker after vitamin C treatment certainly resembles copper. Some dry acid in its place might work.
    Jun 2016
    Vestavia Hills
    34
    I have ordered some copper test strips to see what kind of levels I have!
    Jun 2016
    Vestavia Hills
    34
    Texas Splash- Any recommendations on what to use?
    Have read Jacks Magic- The Blue stuff is good but pricey
  20. Back To Top    #20
    Jun 2014
    15,233
    Jack’s Magic Stain ID Kit for about $15 is the only one I'm familiar with. But if you do in-fact confirm it's copper, you may have heard the metal routine before but I'll toss a few reminders your way:
    - Removing/exchanging the metal-filled water is always idea (if possible) to avoid continued sequestrant use later; or at least maximum water change to minimize the effects
    - Probably best to allow pH and FC to ride a little lower which might help reduce the precipitating effects between chlorine and metal; no doubt your last FC increase prompted this reaction. Hopefully you are algae-free, otherwise you'll be starting all over. So definitely make sure your water is algae-free before trying to manipulate the metal in the water.
    - If you keep the water (or most of it) and continue with chemical management, ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular) and the Blue Stuff (fresh plaster) are some of the top sequestrants. You're right, they are not cheap and will continue as long as you have that metal-filled water (if confirmed). You can also find other brands with similar products, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.
