Thread: Bestway 22' x 52" round AGP - filter/pump/SWG recommendations
    Jul 2016
    Noblesville, IN
    30
    New to the forum but have read a lot. Struggling to find the right answer.
    What pump/sand filter combo would work well for this size pool?
    What size SWG would be ideal?
    Thanks so much for your input.
    Pete
    Pete and Family
    Graduated from baby wading pool to Quick Set Intex 10 ft to Intex steel frame 12 ft over the last 5+ years
    Just purchased BestWay 22 ft x 52 in on clearance - will graduate to it next spring!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Bestway 22' x 52" round AGP - filter/pump/SWG recommendations
    Welcome to TFP
    Using poolmath above it says you have about 12500 gallons http://www.troublefreepool.com/calc.html
    A 1hp 2 speed pump would be great for that size pool but most sand and pump combos come with a 1 speed like this
    Amazon.com : Best Choice Products® Pro Above Ground Swimming Pool Pump System 4500GPH 19 Garden
    A good size SWG for your pool would be from 30k to 45k
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    I hope this helps
    Jul 2016
    Noblesville, IN
    30
    Thank you! Will update as we make our purchases. Ordering test kit today.
    Pete and Family
    Jul 2016
    Noblesville, IN
    30
    Quick update. I kinda went cheap on this but hope it'll still work.
    Went with Intex for both. My pump and filter:
    Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2450 GPH System Flow Rate, 110-120V with GFCI Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2450 GPH System Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    My SWG:
    Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O. (Electrocatalytic Oxidation) for Above Ground Pools Amazon.com : Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O. (Electrocatalytic Oxidation) for Above Ground Pools : Patio, Lawn Garden
    The pump and filter are new. The SWG I got off CL for $50, in unopened box. Both are for more gallons than I have (by at least 20% if my calcs are correct.
    So I think I'm set up for next spring when we erect the 22' bestway pool. All that's left to buy are adapters to go from intex hoses to whatever is on the bestway unit.
    I also think I've settled on a final location, so we will plan to do site leveling and security/privacy fence this fall. Building the fence area 32 x 32' so we could go up to a 27' pool and still have room for a walkway style deck around all or part. Here's a quick sketch of what I'm looking at. Any input you have is welcomed.
    Pete and Family
    Jul 2016
    Noblesville, IN
    30
    Update long overdue!!
    Pool is up. Have been swimming for about 2 weeks now.
    Still have to do a deck but that can wait for now.
    So far the Intex pump/filter and SWG are working great. Have a wide mouth skimmer on order and will install soon.
    Testing is going well - still fine tuning my pH (wants to rise a bit), but after starting with bleach the SWG is keeping Cl right in the 4-6 range and CYA is 70. I still get some sediment on the bottom but getting less and less all the time and the skimmer should help reduce that even more.
    Thankful for all the great info and experts on this forum!!
    Pete and Family
