Thread: How to keep pool from turning green while I'm on vacation
    Jul 2016
    Austin, TX
    3
    Question How to keep pool from turning green while I'm on vacation
    Hello, folks. Long-time lurker, but just gotten serious about the TFP method this season, now that I have my powerful pool test kit.
    Anyway, my question is... I'm going on vacation for 2 weeks later in July. I don't have anyone who can really help maintain the pool while I'm gone. Assuming my pool is in good maintainable shape by then (which it's not, but I'm in the process of a SLAM, and it's coming along...) how can I keep it from devolving into an algae-pit while we are gone?
    I was thinking of getting one of those floaty things for chlorine tablets, and keeping it dispensing chlorine while I'm gone. The teenager who is feeding the dogs can probably re-up the chlorine floater if needed, but I don't think I can ask her to do tests or deal with liquid chlorine or anything like that. Will this work? Any other tips to keep us from losing all our progress in pool maintenance while we are away? (It's outrageously hot here and promises to continue to be.)
    Thanks so much in advance,
    Pamela
    Mom, tech support and pool scientist keeping a 5,000 gallon Intex-style above-ground pool safe for humanity.
    5K gallon above-ground pool with metal frame and vinyl liner. Sand filter pump. Have SWG but it's not working right now so I'm doing the chlorine thing.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How to keep pool from turning green while I'm on vacation
    Three things you can do when on vacation:
    1 - Raise FC to the recommended shock level for your CYA just before leaving. See Chlorine/CYA chart.
    2 - Put a floater with trichlor tablets in the pool. This will also raise your CYA, so be prepared.
    3 - Cover the pool with a solar cover (blue or opaque) to help reduce FC losses to sunlight.
    Make sure pool is pool water level is high enough to account for evaporation until you are returning to the pool.
    Isolated Spa - 345 Gallons
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Or you could repair the SWG and fire it up.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    You could also set out pre measured chlorine for her to pour in the pool after she swims because we both KNOW she will! LOL
    Kim
    Sep 2015
    Rome, NY
    363
    How much liquid chlorine do you normally add each day? For example, can she just do a quart a day?
    Therefore no testing.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
