Results 1 to 14 of 14
Thread: Chlorine floatie keeps getting stuck near ladder!
    Jul 2016
    Ringwood/NJ
    4
    Hi All,
    I have a typical chlorine floatie for my chlorine tabs and whenever i put it in the water with the filter on, it makes a few circulations around the pool (12 foot round, 4.5 feet deep) and then always gets stuck by the ladder.
    I am thinking of switching to granular chlorine and just mixing it with water and dumping it in the pool.
    Any assistance would be greatly appreciated.
    Thanks All!!
    May 2013
    High Point NC
    22
    Re: Chlorine floatie keeps getting stuck near ladder!
    This site doesn't really recommend using pucks, floaties or granular chlorine for reasons explained in the pool school section of the website. I would suggest you read through pool school.
    25K Gallon IG vinyl lined L shaped Haywoard Pro Series sand filter, T-CELL-9, Super Pump
    415 Gallon Leisure Bay Spas Elite Series Cordova Hottub
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    Hi and welcome. Check out this article on recommended pool chemicals.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    Ringwood/NJ
    4
    It is a very small pool and all my levels are fine. I am not into studying pool chemistry, buying a million different kinds of products or reading a 2,000 reply thread.
    Anyone have a simple solution here?
    Thanks.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    Bleach
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Take it out?
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Jun 2016
    Poplar Bluff, Missouri
    344
    Quote Originally Posted by Aquaman1969 View Post
    Thanks.
    That's the beauty of the TFP way, you don't have to buy a million different products. I've only had to buy one, bleach.
    AGP: 21' x 52" : 10,000 gallon
    100 lb. Sand Filter / 1 hp pump
    11-5 full sun
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Thanks.
    Aquaman1969 - I'll take a stab to answer your question the way it was intended:
    1. In a small pool the floatie being stuck in one area isn't in and of itself problematic. the contents will slowly dissolve in that area by the ladder and your pump will circulate the chlorine.
    2. If you choose to switch to a granular chlorine, there is no need dissolve in a bucket first. You can gently broadcast it over the surface and it will dissolve quickly. But this is still daily maintenance which I get the impression you are looking to avoid.
    3. If you are willing anyway to do the extra work of having to dose granular every night <AND> you already suggested that you would take on the extra added effort of dissolving in a bucket, then yes - Bleach, or liquid chlorine is an easier and viable (preferred) option. Just be aware that whether you go liquid or granular, this is a task you have to perform every night.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jul 2016
    Ringwood/NJ
    4
    Thanks mike! Much appreciated!!!! Looks like the weather is finally coming around here in the northeast for extended pool time!
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Certainly is!! Look into these Pool Ladder Guard Panels. They are probably specific to each manufacture. But the purpose is so automatic cleaners and "stuff" doesn't get caught behind the ladder. They clip onto the side of the ladder. Here's an example from Amazon. But try searching around for something that fits your application.
    Amazon.com: Zodiac G21 2 Panels Ladder Guard Replacement: Patio, Lawn Garden
    Jul 2015
    Central Valley CA
    1,109
    I suspect you could build a ladder guard with a couple of zip ties, a piece of PVC and a heat gun. Heat the PC bend it to create a gentle contour on each side of the ladder and use the zip ties to attach it just below a step near or slightly below the water level.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    A stuck floater dropping acid and chlorine in one spot in a vinyl pool will bleach the liner and possibly damage it.
    22,553
    As Pooldv said, both low pH and high FC won't make the vinyl happy.
    What about anchoring the floater in the middle of the pool using a weight and string? Thought about that?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Seasonal pool? Don't sweat it. If you must use pucks, go ahead and tie/leash the float on the down flow side, or take a $1 pool noodle and wedge on the up side of the flow so it pushes the floaty away from the backside of the ladder.
    Another option how easy is it to remove the offending ladder?
    Keep an eye on your CYA (Stabilizer) level, and adjust your chlorine level upwards accordingly.
    How long is your pump run time? Are you brushing weekly at a minimum? Without the ladder in place your brushing would be easier.
    Just some ideas. Good luck and enjoy your pool.
