Thread: PH has me just a little nervous.
    grumpy's Avatar
    Jan 2009
    Coastal South Carolina
    64
    Test from last night.
    FC-5
    CC-0
    PH-7.7 (just a bit on the pink side of 7.6)
    TA-70
    CH-250
    CYA-70
    Salt-3590
    Pentair says that the intellichlor IC-40 will cause PH to stabilize around 7.8 and I guess they are right. Seems like everyone here recommends adding muriatic acid when PH gets to 7.8. My problem is I don't ever seem to get there. Last time I added muriatic acid was April 5th and that was when I was adding a bunch of other stuff trying to get the water in balance.
    Sigh, since I can't pour stuff into the pool I'll have to content myself with playing with the SWCG. Let's see, FC is a little high, I had it up for a party on Memorial Day, guess I should turn it back down to 10%.
    I think I'm going to enjoy my Trouble Free Pool this year.
    12170 Gallon in ground San Juan Caesar's Palace fiberglass with integral Spa in a screened enclosure. 1 HP Pentair Whisperflow pump with Pentair Sand Dollar SD-80 sand filter. Intellichlor IC40 with EasyTouch wireless remote. Aquacal Heatwave Heat Pump. Taylor K-2006 and Aquachek Salt test strips.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: PH has me just a little nervous.
    haha, I just hate it when I don't have to nearly kill myself with acid fumes because of a TFP BBB stable ph...
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Gosh, what a drag, having the PH being stable and all....
    As long as PH is between 7.5 and 7.8 you are fine. From your description you are just fine and don't need to worry about it.
