Thread: Suds on top of water
    I am in the process of adding the bleach and trying to get the water clear. However as my luck goes I have a suds whats causes them?
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a sand filter=300 lbs of sand
    vinyl liner
    30,421
    Re: Suds on top of water
    The most common cause is prior use of an inexpensive algaecide. Regardless of the cause, chlorine solves the issue 90% of the time.
    It can sometimes take up to a week for the foaming to go away, sometimes even longer if you are fighting algae at the same time.
