Thread: Longtime ionizer user with staining algae/metals problem
    Jul 2016
    Summerville, SC
    15
    First post, love all the info all the members give, love the do it yourself better for less reality
    So about my pool chemistry I am a longtime user of a floatron ionizer, that and liquid chlorine shock have always worked when I lived in Michigan.
    I now live in SC near Charleston and inherited a neglected and let go pool a few years ago with the home I purchased. This year I opened it and it was fine until the spotchy mostly blackish with some green tint spots showed up on the bottom of the vinyl pool only. Will not brush off feels like the liner if you rub a spot and I inspected them up close with a mask on. Pool is crystal clear.
    I tried a few things like more liquid chlorine, then the Clorox algae side product, then Clorox shock.
    today I took some of the granular shock put it in a sock and with my crocks on in the pool held it on various spots, it seemed to lighten them up.
    so I vacuumed the pool, hit it with double shock treatment and a bottle I found of Royal 60 algaeside.
    Ran the pool for 2 hours on circulate and just went out to look
    The pool is a bit cloudy now but with a flashlight they look to be mostly gone
    Bumped filter from circulate to filter and will let it run all night
    TF100, 15k gallons, 27 ft round, AG, Vinyl, Hayward Sand,
    Hayward 1 hp, City Water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Longtime ionizer user with staining algae/metals problem
    Welcome to TFP!
    If the powdered chlorine lightened the stain and raising the chlorine level lightened it further then the stains are organic. Raising your FC to near shock level for your CYA and brushing often will remove the stains in a couple of weeks or so. FC/CYA Chart
    Order a TF-100 from TFTestkits.net. It isnthe best test kit value by far. I've been buying mine there for years. Pool School - Test Kits Compared
    Jul 2016
    Summerville, SC
    15
    Thank you,ordered the Tf-100 today
    The algae spots do look a little faded today
    my plan is to use the test strips and keep the free chlorine level up
    Jul 2016
    Summerville, SC
    15
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Do I need to continue running my filter 24/7?
    DFW, TX
    24,450
    No, I don't think running it 24x7 will help much. Brushing probably helps most. Might as well save some bucks on electricity.
    Jul 2016
    Summerville, SC
    15
    Does some algae not brush off?
    I know black doesn't on a concrete pool
