Thread: Can't find capacitor. HELP?
    Jun 2016
    ROANOKE, VA
    9
    I have a cheap pump. It came with the Pro Series AG pool. CP2000 cartridge pump.
    The unit is just humming. Not doing anything else.
    I took the capacitor out and had it tested. It is dead!
    This is a CBB61, 14uf, +/- 5%, 250 VAC, 3 terminal/ prong. Squareven capacitor.
    I can't find a source. I have asked State Electric, Grainger, every pool store in the county, HVAC repair shops, Lowes, Home Depot, Graybar, Wesco, etc..... eBay has one but not 3 prong. Amazon doesn't have the right voltages. I have struck out. My pool is just sitting there without a pump. Help!
    13,500 gal AG vinyl soft sided pool (Pro Series), 24' round, with CP2000 cartridge filter/pump. NEW POOL OWNER. was using Baquacil and converting to chlorine
    Jun 2016
    Martinez, CA
    207
    Re: Can't find capacitor. HELP?
    Can your u show a pic of the top of it may have 3 prongs (some have even more) normally there are only 2 actual posts.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    22,548
    Since it's a single uf value, two of the terminals are connected internally.
    Find one that matches the 14uf, 50/60 hertz, physical size and matches or exceeds the voltage rating and it'll work fine.
    If you can't find one with spade lugs, you can add male spade connectors to the leads and use those.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,776
    +1 to what Bama said
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
