Results 1 to 7 of 7
Thread: Help identifying stain
    Jun 2016
    El Paso, TX
    38
    Hey guys I have a stain that I have had for years cant figure out what it is, or how to remove it. I have tried scrubbing and scrubbing also vitamin c.
    Here is 2 pics! thanks
    Jun 2014
    15,217
    Re: Help identifying stain
    If it's dark in color (obviously) and/or rough, it may be scale from excess calcium. Can you post a full set of water test results?
    You've already tried vitamin C, so now you can try a tri-chlor puck on the area to see if it's organic. As a last resort, there are some over-the-counter methods to ID a stain (i.e. Jack’s Magic Stain ID Kit – about $15) that can be used to help identify the cause of a stain.
    Jun 2016
    El Paso, TX
    38
    Quote Originally Posted by Texas Splash View Post
    I did try a puck! No luck. Also...my calcium is just a tad bit high at 725! Lol, i am draining pool in a month or two. We had that stain when we draines 4 years ago, how can i get rid of it if it is calcium scale?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Dry acid in a sock. But, that isn't calcium scale. Try putting a Vit C tablet or two on there and leaving it until it dissolves.
    Jun 2016
    El Paso, TX
    38
    Quote Originally Posted by pooldv View Post
    So its not calcium? Its on sidewall how can i do that? I scraped some vitamin c and it stayed on for a few days then i scrubbed and nothing happened.
    DFW, TX
    24,504
    Oh, I see. It looked like it was on a step at first. That is a little trickier.
    I don't think it is scale. You can get some dry acid, sodium bisulfate, and put it in a sock and rub it in the stain. Is it rough or raised texture?
    Jun 2016
    El Paso, TX
    38
    It almost seems embedded but maybe a tiny bit raised, i will really check tomorrow ans try that
