Thread: Wanting to change out Summer Escapes return jet
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    336
    i am wanting to change out my summer escapes return jet. i was looking at the intex return jet. i dont see them for sale anywhere anymore. i know i will have to make the hole a bit bigger to accommodate a new jet. i was wanting one that i can move the eye around as needed. the one now i have to unscrew the whole assembly to get it to move. any recommendations?
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: Wanting to change out Summer Escapes return jet
    I replaced ours with a Hayward return when we had our pro series pool. It did require a larger hole to fit but you are already prepared to cut it larger to replace it anyway. It is nicer in that it is more directional and can accommodate any accessories such as fountains or pressure cleaners where as the intex return won't. Bought it on Amazon for less than $20.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    chayne's Avatar
    May 2016
    336
    i saw those, but i did not know how hard it would be to add to my pool. what type of fittings are on those jets?
    is this like the one you are talking about?
    Amazon.com: Hayward SP1419D White 3/4-Inch Opening Hydrostream Directional Flow Inlet Fitting with 1-1/2-Inch MIP Thread: Patio, Lawn Garden
    also, do i need this too?
    Amazon.com: Hayward SP1023 1-1/2-Inch FIP Inlet Return Fitting with Locknut and Gasket: Patio, Lawn Garden
    Charles
    Coleman 16'x48"
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Yes you will need both of those to go that route. It uses standard 1.5" threaded pvc fittings. You will use this to connect a regular return hose to, tightened with a band clamp. Or you can use standard sch40 pvc and hard plumb if you are using a different pump and filter than the built in one.
    chayne's Avatar
    May 2016
    336
    I have everything hard plumbed on my pool except for the return. Have not done it yet because I knew I wanted to change out my return. I appreciate the info
    Charles
    Coleman 16'x48"
