Thread: New pool and test kit...looking for advice
    Jun 2016
    Germantown, WI
    3
    Hi all,
    My wife thought it would be a great idea to get a pool for our kids. "They are only young once, you know." Well, we know have a pool (Intex AG 16'x48", sand filter) and the kids are thrilled.
    I started this adventure with zero knowledge but luckily stumbled onto this forum before I even started putting the pool up. We bought our setup used from a neighbor that gave us all the equipment we needed, chemicals and lots of advice. Included in the setups was a two part ph and chlorine (oto) test kit and a new bottle of 7-way strips. Seemed like I was off to a great start. (Hey, what did I know...)
    Got water in the pool, threw in some liquid chlorine (at least I did that right). Next day, chlorine was gone and I learned about stabilzer. Kept reading here and realized I had a lot to learn. Went through pool school and realized that I needed a better test kit. Went to the pool store for their free testing and the girl there came out with the same test strips I was already using. She then proceeded to tell me all of the things I needed for my pool. Let me just say, thanks all of you here. If it weren't for the reading I had done on the forum, I would have spent a LOT of $$ that day.
    I went home and ordered my TF-100 and hoped the pool didn't turn green before I got the kit.
    Well, the kit came today and I ran my first tests. Here are the results
    FC: 1.5
    CC: 0.5
    PH: 7.8
    CYA: 20
    TA: 450
    CH: 625
    I went right out and added more liquid chlorine to get my FC up to 3 per the chlorine/cya chart and I have some stabilzer left so I will be getting my CYA to 30-40 in short order. PH is a little high, and I have some PH down for that (will get some muriatic acid soon).
    My questions are about the TA and CH. Admittedly, I have only lurked around here for a few weeks, but those seems high (like I did something wrong, high...but I did the test twice).
    All advice is welcome.
    Thanks.
    5061 Gal. Intex round 16'x48" AG (bought used from neighbor)
    1/2hp pump Aquaquik (made be Game Inc.) sand filter, single speed
    Installed 6/11/16, Opened for swimming 6/18/16
    Test Kit: TF-100
    May 2015
    Land O Lakes, FL
    527
    Re: New pool and test kit...looking for advice
    Looks like you are off to a great start.
    PH is at the upper limit, you can bring it down a little if you want and with each time that you add acid to lower ph, it will lower total alkalinity.
    Here are the instructions to lower total alkalinity: Pool School - Lower Total Alkalinity
    I will let the others chime in on calcium hardness.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jul 2015
    Central Valley CA
    1,109
    Not much you can do about the CH must be in the fill water. I would test the tap water if you get a similar result that will confirm it. Many have levels that high, I would keep your pH on the low side of the range and lower the TA. You want to keep your CSI on the slightly negative side say around -0.3 that should avoid scale. You can see the CSI level change in PoolMath as you adjust pH and TA.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Germantown, WI
    3
    Thanks MGMOORE7. I am working on the ph now. This morning it was down to 7.5.
    ATTTECH-2, great idea to test the fill water. I will do that after work tonight. I am not sure what CSI is and its function, but I see how the component parts impact it in Pool Math. I guess I have a little reading to do...so much to learn. Thanks for your insight.
    It is really great to have a resource like this forum.
    Test Kit: TF-100
    Jun 2016
    Germantown, WI
    3
    Quote Originally Posted by atttech-2 View Post
    Well, I tested the tap water as suggested. TA was 440 and CH was 550. I think I understand how to get TA down with muriatic acid and aeration. I just have the stock return from Intex and it does not really break the surface of the water, so I will have to come up with something to facilitate aeration. Suggestions are welcome.
    Last question, should I be concerned with CH levels that high?
    Test Kit: TF-100
