Results 1 to 10 of 10
Thread: Adding CYA in sock
    Jul 2008
    Seacoast, NH
    253
    Adding CYA in sock
    I added CYA by sock method today. How long before I should expect the CYA to be reflected in the CYA test. I know it's a week if you just add it to the skimmer; I assume it's faster if you use a sock.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: Adding CYA in sock
    You should be able to get a reading within a day of it all being dissolved. I get in the pool and squeeze those socks and swim around with them to get them to dissolve.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2007
    Hillsborough, NC
    525
    The CYA I got to start up a new pool last weekend the directions were to pour it into the skimmer then wait 3 days for it to be dissolved. My experience with the sock method is after putting the sock in the skimmer a few days later there was still a lot of CYA in the sock, so I ended up just working the sock in the pool until all the product was out. The next times I added it, I put the sock in the water to let everything get saturated, then I just worked the sock until it was all worked into the water. I can't imagine it taking a week for it all to dissolve. I discovered today that I was out of the CYA reagent, I will get more tomorrow. That will be day #4 for the CYA, so I figure I will test tomorrow and see what it's like.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jun 2016
    Poplar Bluff, Missouri
    344
    I've added mine in a sock in the skimmer but end up holding the sock in front of the return and squeezing it until it's all dissolved, actually only takes about 30 minutes and it's all dissolved.
    AGP: 21' x 52" : 10,000 gallon
    100 lb. Sand Filter / 1 hp pump
    11-5 full sun
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    That sounds like what I do. I work those socks in front of a skimmer when I'm in the pool. But....I don't place them in the skimmer anymore. I tie them to a pool noodle and let them float. Then when I can get back to them the granules are like fine powder that just needs to be released.
    Jul 2008
    Seacoast, NH
    253
    Oh, all the CYA was dissolved within 2 hours. Carpal tunnel from all the squeezing.
    1.5 HP Pump
    Jun 2016
    344
    And fortunately I only have to work about 1.75 pounds of it two different times, unlike some of you folks whose pools require more CYA..
    11-5 full sun
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    122
    Warning about CYA. I opened my pool in mid June with 0 CYA. It was a black pond. I cleared it nicely after 2 weeks and all the levels are OK now. I was shocking it but also pumping it with tricolor tablets. I probably went through about 12 tablets. My CYA was 75 today and now I just relax. I know it's a bit high but it will go down as I top off the splashed water. Plus, I don't mind adding about 33 oz of sodium hypo pool strength chlorine every other day or so. So just run 3-4 tablets in skimmer depending on size of pool if you want to add CYA. It will rise quickly from my experience. Just my 2 cents.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by markuszoom5 View Post
    We generally don't reccomend chlorinating with pucks due to the constant addition of CYA.
    Jul 2013
    Waxahachie, Tx.
    448
    Ihave a piece of pvc i tie a sock to and put it in front of a return. The time to disolve depends on how often you can squeeze it
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
