Thread: Pool is green need help
    Jun 2016
    Mount Olive IL
    2
    Been fighting it since Memorial Day. Finally got the test kit here are my numbers.
    FC=.4 ppm
    CC=.4 ppm
    PH=7.6
    TA=60 ppm
    Ch=240 ppm
    I have a 27' round AG 1.5 hp pump Tagelus sand filter. Using Taylor K-2006 test kit
    Jun 2015
    Glendale, AZ
    156
    Re: Pool is green need help
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jul 2015
    Central Valley CA
    1,107
    Welcome to the forum
    What kit did you get? You are going to need bleach lots and lots of bleach aka liquid chlorine. Have you had a chance to read some of the articles in pool school? You should start with the ABC's then read the directions for SLAM in the solving problems section defeating algae. One of the main things to understand is SLAM is a process not a one time treatment it will take some time to complete but once you are done controlling the pool will be much easier from that point on.
    The FAS-DPD test can test down to .2 ppm FC but there is not much reason to be that precise stick with the .5 ppm test 10ml sample size it will save on reagents. Read the SLAM directions and come back wiht questions others will be along shortly with more suggestions.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
