Thread: Intellichlor diagnostics
    Aug 2011
    North Fort Worth, TX
    131
    Short story...Pool is almost 5 years old. This summer we have had issues keeping chlorine in the pool. Intellichlor IC40 constantly blinked check cell despite cleaning multiple times with water/muriatic acid. Cell showed 60% usage and failed to connect to Easy Touch showing COM LINK ERROR. Talked to a pool maintenance guy in our neighborhood and he said time to replace SWG. Replaced tonight with same SWG and it still shows COM LINK ERROR. All LED lights are green (cell no longer blinking). Help! I'm about to fill my pool in with dirt
    Pool store said salt is 3400 and I verified at home with test strips. Pool store also said phosphates were 500?!! I have the large test kit and it doesn't test for phosphates but all other numbers are within range. We've SLAMMED the pool and have been manually adding chlorine via bleach while we waited to replace SWG.
    Built in 2011, 23x34' IG freeform play pool (18,850 gallon) ~ 7' spa raised 18" with 5 jets, 3 tier fountain and 5 tier cascading waterfall into pool ~ IntelliChlor SCG ~ Pentair Intelligent VS-3050 variable speed pump ~ Clean and Clear 420 cartridge filter ~ Easy touch controller ~ Blue Granite Pebble Sheen ~ Intellibrite LEDs ~ Turbo twister slide ~ 8x8 flagstone tanning ledge with umbrella sleeve and bubbler ~ In-pool flagstone table with umbrella sleeve ~ 997 sq ft exposed aggregate decking Our pool build
    Aug 2011
    131
    Re: Intellichlor diagnostics
    No advice?!! I've tried reconnecting all the cables, resetting the system shows OK for a bit but doesn't read salt level and reverts back to COM LINK ERROR within 5 minutes. New salt cell is producing chlorine.
