Thread: Glycerin Gauge Question
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Ok, got tired of the El cheapo gauge that goes to 60 psi and my running pressure so low its pretty much impossible to detect a 20% rise. It was time for some regent refills from TFT anyway so I added the gauge.
    It was delivered today. It sure is purdy compared to the current one!! Nice and solid too!!!
    Ummm, but what's with this pull the plug and replug part? I hope I only have to do it prior to install because it will be horizontal once installed. Won't the glycern just run right out? Also, is the air bubble in it now ok, or is that what pulling the plug will release?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Glycerin Gauge Question
    I KNOW there has been a thread on this........and not sure if you need to do that step or not. I'll search unless someone with a better memory than mine chimes is.
    See if this helps clarify
    D.E. Filter PSI Guage 0-30 PSI Glycerin-filled - Question
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2015
    380
    Hmmm, maybe? Don't cut the tip, but if you do it doesn't matter? Mine has the plug, but some ignore it and another thinks it needs equalizing frequently.
    Seems like it probably doesn't make a big difference either way.
    Scott
    Mar 2015
    380
    Thanks AimeeH I had searched but was obviously using poor key words. Finding a few others after the one you linked. Answers still vary but Duraleigh posted on a few of them to only worry about it when it's not reading zero with the pump off. Since it has a physical stop it looks like I only need to worry if it is reading some kind of mystery pressure with no pump.
    Scott
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Well.......I have the same gauge and maybe you just helped me. I was getting wonky readings after a year so switched it out for an el cheepo. Still have it set aside. Now maybe I'll come back to it and I should have read instructions?
    Mar 2015
    380
    This site seems to always have the answer, so if it relates to my pool in any way I seem to forget that Google is otherwise my best friend
    Great article here about it and I did see one reply on one of the threads it was more for any difference in atmospheric pressure.
    Venting and Filling a Liquid-filled Gauge
    Scott
