Thread: Understanding liner cost.
    We're facing a new liner, and I'm trying to understand the costs. Using this site, I get the following for our existing pattern.
    Group H - Blue Hampton 20 mil - $1544
    Group I - Cambridge 30 mil - $1739
    Group J - Blue Hampton 28 mil - $1836
    Can anyone explain why the "Group J" is thicker, cheaper, and called something different? FWIW, our existing liner (Cavalry/Ft Worth) is labeled Cambridge 30 mil on the paperwork.
    Also, our warranty shows 20% ($347) prorate at less than 10 years (Installed ~8/1/06), 15% ($261) for 11 years. Is it worth the $87 to change it now, or should patch and wait until spring? Anyone know if the warrant date is based on notifying them, or placing the order?
    My Pool: 18'x36' Grecian. Vinyl Liner, 500# sand filter, SWG.
    My hobbies: Brewing beer and flying rockets.
    Jul 2014
    Ottawa Ontario
    56
    Re: Understanding liner cost.
    According to your chart group J is actually more expensive which makes sense since it's thicker. As for the names, dunno.
    I would look at holding off on installing a new liner. Wait until the end of the season when there are more deals. Of course, this means you will have to patch which also incurs costs.
    Actually I is thicker
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    I have decided based upon my own unproven research, that liner prices are largely dependent upon the following;
    20mil with least attractive colors and patterns - least expensive
    30 mil are next expensive irregardless of colors and patterns
    28/20 and 28 mil with the most attractive colors and patterns are the most expensive.
    In a nutshell, whatever is generally considered to be the most attractive to the majority will have the higher price tag.
    Divin Dave,
