Thread: Test Kits
    Apr 2016
    Houston, TX
    23
    Test Kits
    I am sure this has been discussed before but I wasn't able to locate that thread. I currently have a Taylor K2005 test kit and need to be able to test chlorine levels with the FAS/DPD test. Should I just buy that kit individually, or buy the K-2006 or the TF-100 test kit from TFTestkits.net?
    15000 Gallon, Taylor K-2005 Test Kit, DE Pentair filter.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Test Kits
    All you would need is the FAS-DPD test.
    FAS/DPD
    Isolated Spa - 345 Gallons
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Test Kits
    No, just order the FAS-DPD individual test and your K-2005 will be equivalent to the K-2006. Go to TFTestkits.net It costs about $26.
    I'm more a fan of the TF-100 as it gives more test reagents for the tests you do the most. But since you already have the Taylor one just add to it.
    Apr 2016
    Houston, TX
    23
    Re: Test Kits
    thanks guys for the replies, i'll order the kit now.
