Thread: TA / pH chart to quickly choose the correct adjustment
    Jul 2015
    Biloxi MS
    37
    I think I can use some help here. I've begun to create a chart that can quickly show me what action to take when making pool chemistry adjustments, but I have three blanks. Can you fill them in for me?
    pH high and TA high: add muriatic acid
    pH high and TA good:
    pH high and TA low:
    pH good and TA high: bubble air
    pH good and TA low: add baking soda
    pH low and TA high:
    pH low and TA good: add borax
    pH low and TA low: add washing soda
    Intex 10' vinyl above-ground pool, only 1200 gallons, with 55-gallon gravity-flow sand filter, shaded by a tree in the morning then exposed to full sun all afternoon
    30,413
    Re: TA / pH chart to quickly choose the correct adjustment
    pH high and TA good: add muriatic to lower pH; Bring TA back up with baking soda
    pH high and TA low: bring TA up over target; Lower pH and TA comes with it
    pH good and TA high: bubble air] Use acid and aeration per Pool School article
    pH low and TA high: add 20 Mule Team Borax
    Mod Squad pooldv's Avatar
    DFW, TX
    24,471
    Put this cheat sheet with your new cheat sheet, Pool School - Recommended Pool Chemicals
    Jul 2015
    Biloxi MS
    37
    Thank you, I appreciate it.
