Thread: Temperature not consistent throughout pool
    Jun 2016
    Oswego ny
    5
    Greetings,
    I have a Coleman 16x48 Power Steel pool. I installed a skimmer in it a few weeks ago with tips from this site.
    It does a nice job of keeping the surface clear. However I'm having an issue and I had this last year before the skimmer.
    The water on the first foot or so is warm,however below that is is a lot cooler. I used a solar cover this year and it still has
    the issue,I even just bought one of those Intex solar mats that the return water runs through. I just checked the floating
    thermometer,it is about 86 deg. But I stick my arm in and once past that upper foot of water it is a lot cooler. The pool is in direct
    Sunlight . Any ideas ?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Temperature not consistent throughout pool
    With a single return in the pool, you're going to be trading between surface skimming and deeper mixing. If you aim the return along the surface, you'll get great skimming. If you aim in the same direction but more downward, you'll get better mixing with the deeper water, but the skimming will not be as good. I would tweak the return to run a little more below the surface or when you put the cover on, unscrew the return eyeball about 1/8 of a turn so it aims slightly downward to get better deep circulation.
    Isolated Spa - 345 Gallons
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I don't think this is abnormal. Direct your returns down. That may help get the surface water to the bottom.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    You have a thermocline. I have two thermometers, one at the surface and one on the bottom. When my wife wants to know the water temp, I report both readings, just for giggles. Yes perfectly normal and the posters above have hit the nail on the head.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jun 2016
    Oswego ny
    5
    Return is pointing down,I will see how it is tomorrow
    Casey's Avatar
    SW PA
    10,457
    Completely normal.
