Thread: Just filled up Intex Easy Set pool. What now?
    Jul 2016
    Beaumont, Ca
    4
    Hello Everyone. Im new here and just finished setting up and filling up a 16x42 Intex Easy Set pool. (says 3700 gallons of water).
    My first question is, what is the first step to take before letting my daughters jump into the pool? I ordered a test kit off amazon(TF-100) but I was wondering if its safe and ok to let my daughters jump in the pool or wait until I test the water?
    When and how long do I run the pump for? (intex pump that came with the pool).
    I'm new at all this so I appreciate all the tips and information I can get.
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Just filled up Intex Easy Set pool. What now?
    It's safe to jump in as long as you can see the bottom. For your purposes, the easiest start up might be here: Pool School - Guide for Seasonal/Temporary Pools
    Isolated Spa - 345 Gallons
    Jul 2016
    Beaumont, Ca
    4
    Thanks a lot!! I will be taking a read
    Jul 2016
    Beaumont, Ca
    4
    ok, so I've read the link and went out to buy a 3 way test kit at walmart. I poured the suggested amount of bleach last night in to the pool and also added CYA and tied it to a sock and have it hanging close to the return.
    My question is, is it ok to go and have a dip inside the pool or should i wait until this weekend?
    Here's what my test indicated as of this morning:
    FC: 2
    Br: 4 (not sure what this stands for. Bromine?)
    pH: 8.2
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Br is bromine, which you will not have unless you added it. You can ignore that reading on the test block. You need to bring the pH down to around 7.2-7.5 Get some muriatic acid, http://www.troublefreepool.com/calc.html will tell you how much to add to lower pH. Other than that you are good to swim when your FC is in the recommended range for your pool and the water is clear.
    Those pumps are notoriously underpowered so I would run the pump whenever there is no one swimming.
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Beaumont, Ca
    4
    Awesome! =) I will go out tomorrow and buy the muriatic acid and definitely keep the pump running when no one is swimming.
    thank you.
