Results 1 to 7 of 7
Thread: Intex SWG GFCI tripping
    Jun 2016
    NE Kansas
    16
    Hello,
    I have the latest Intex SWG and noticed my pool getting cloud and noticed that the GFCI on the plug in won't reset or anything. It's brand new, i've not even had it for a month. I've tried different outlets and those don't work either. Any suggestions?
    Intex Rectangular Pool 18x9x52
    Intex 110-120V Krystal Clear Sand Filter Pump
    Intex 120V Krystal Clear Saltwater System CG-28667 w/ E.C.O.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Re: Intex SWG GFCI tripping
    If you have a GFCI protected outlet available, cut the GFCI off of the Intex cord and replace it with a regular plug. Then plug it into your GFCI outlet.
    I had to do this with mine, but for another reason. I use an external timer to run my pump and SWG, and it tripped the GFCI on the pump every time it turned it on.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2016
    NE Kansas
    16
    Thank you so much for the help!
    Jul 2016
    Markham, Texas
    4
    I just put up a new Intex 16' x 48" pool with their SWG unit. My SWG GFI unit got wet when I was venting the filter canister next to SWG and it has quit working also. So I too, just cut it off and installed a regular male plug on the cord and swapped the receptacle out for a GFI type. They are supposed to be water proof, this showed me that they aren't.
    Jun 2016
    NE Kansas
    16
    That's so crazy! I thought they were suppose to be. I ended up contacting Intex and they are sending me a new swg. Hopefully this one doesn't cause any problems!
    Jul 2016
    Markham, Texas
    4
    Glad to hear Intex is standing behind their products, my GFI unit had some strange screws holding it together so I did not bother taking it apart. Hopefully your replacement GFI won't have the same screws mine had...
    Jun 2015
    Michigan
    13
    Just did it to my brand new sand filter everytime it kicked in with the timer the gfi would trip
    Intex 18x48 - Intex sand filter - Intex SWG
