Thread: Plunger valve - small knob
    I have a question about these intex plunger valves. There is a small knob next to the nut that screws it on to the pool. What is that used for?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Plunger valve - small knob
    Kinda looks like it is there to allow you to get air out of the system.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jul 2015
    Port Neches, TX
    53
    it is actually an air valve that sucks air in if the vacuum is too strong for the amount of water coming out (like if have a stronger pump than what came with the pool, or if the strainer basket gets blocked). I have to cover mine when vacuuming otherwise my pump loses suction from the air coming in......
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    thank you. Mine was loose and I tightened it but I wondered if maybe I shouldn't have
