Thread: Algae surviving over the winter?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I know on the surface the answer to this question seems quite obvious. But I am following another member's thread regarding Mustard Algae coming back year after year and it made me consider the question:
    If I have hidden algae when I close the pool for the season is it possible for algae (be it green, mustard, black, red, purple, fuchsia) of any kind to survive a northeast winter?
    Pool is always closed with perfect water balance and FC brought up to Shock Level using liquid Bleach. Cover is a safety solid. 100% solid. Not mesh, not a permeable solid. This is a heavy vinyl cover that allows zero light to pass through. In the absence of any light, being subject to freezing temps for months under the cover, and blasted with a 30+ FC upon closing, is it reasonable to surmise that no algae can survive and I should theoretically be opening to an algae free pool every spring?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Algae surviving over the winter?
    Don't see why it's not possible.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by bobodaclown View Post
    Because I am subjecting it 3 conditions in which I am not sure if algae can survive. Complete darkness, Freezing, and Ultra High Chlorine. That's why I asked.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Freezing isn't going to be a problem for algae. It won't grow, but it will still be there. Algae has been found active in Antarctic ice though most of the time it is just spores waiting for better conditions to grow.
    High chlorine will ensure that no algae is alive at closing, but it won't last all winter, and some spores will certainly find their way in under the edges of the cover via wind or bugs dragging them in.
    Absence of light will be the most important thing. Algae can't grow without light.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Thanks JohnT - It was the light/darkness thing I wasn't sure of. Whether or not algae is like any other plant that requires photosynthesis for survival. Appreciate the response.
