Thread: My Pennsylvania Pool Renovation
    Jun 2014
    Allentown, PA
    5
    First, a quick bit of background.
    I purchased a 1957 home with a vintage concrete pool about three years ago. I grew up around pools, as my dad had a vinyl liner pool for 30 years, but I never desired one and had no idea what I was in for.
    - c. 1975 Sylvan pool
    - Lazy L.
    - 28,000 gallon
    - several coats of unknown paint
    - Deep end is about 9 feet
    - dive
    It had not been opened for several years and was a total wreck. No legal fence around most it. The last owner literally had a piece of Romex carrying 220 v to the pump laying across the ground. I pumped it out myself, refilled and got to work. Thankfully, I found TFP to help me manage it. With the safety issues tackled, we are finally getting to the cosmetics. It's a huge investment for my family, but it's here, so we are going forward with making it nice.
    The crew from Premier Pool Renovations arrived to start my renovation this morning. We are going for a clean modern look that matches the home. It will include:
    Deck and coping removal
    tile removal
    sandblast
    Replace with new cantilever deck.
    new tile
    krystalkrete finish
    10-working day at a cost of about $29,000
    My intention is to share photos here, thinking I might just learn something from the experience. And, I'm also open to all of your great insights and suggestions as I go forward.
    First up:
    The crew has demoed and removed the old rusty dive stand (visible in second image). It is a single post metal cast in place.
    My intention was to paint it and replace it, but it will become a permanent fixture again. The 8-foot board is cracked and so I already have to replace that too. Any opinions on whether it would be better off getting a whole new dive? is it preferable to bolt to the new deck instead? any suggested models?
    Part two:
    It's a little tricky because the junction box for my light is tucked under this dive, rising about a foot above the deck. Any ideas on how I should deal with this if I change out the dive? Is it difficult to run new conduit in order to move it off the deck? I presume this will also be buying a new light with longer cord. I am pretty capable with fixing anything, but also need to watch cost.
    Anything else I should pay attention to before they pour the deck? They will be pressure testing the lines at some point.
    thanks! Jeffery
    28,000 gal., circa 1975 painted concrete IG
    2.2 HP; DE Fiter; Spa with Raypak heater
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: My Pennsylvania Pool Renovation
    Missed this thread!
    Can't wait for more pics, especially after you get the water clear.
    Good luck and be sure to check back if you have questions!
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    241
    Wow, that pool will be a beauty when completed. Love the vintage pools. Great looking house as well.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
