Thread: Going on vacation for 5 days
    May 2016
    Toms River, NJ
    61
    I will be going on vacation for 5 days. With a CYA of 40 and direct sun for most of the day, I'm currently adding half a bottle of bleach every day or two. I will be gone for 5 days without anyone to care for the pool, and no cover. If I bring the pool up to shock level, will it be OK for the 5 days? Or is there something else I should use?
    Thanks!
    18k gal 32'x16' IG vinyl, sand filter, TF 100 test kit
    Newbie pool owner since April 2016
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Going on vacation for 5 days
    It will probably be OK. You can add a few trichlor pucks in a floater for extra insurance, don't put it in the skimmer basket. The pucks will lower PH so don't lower PH too much if you are going to add some pucks.
    Check the Effects of Adding Chemicals toward the bottom of Poolmath to calculate what a trichlor puck will add to the pool.
    30,431
    I would bring it to SLAM value and then add 3-4 pucks to a floater. That would probably do it but I would hurry home after your five days.
