Results 1 to 9 of 9
Thread: Pool Pump Timers
    Jul 2007
    Hillsborough, NC
    525
    Pool Pump Timers
    The house we sold I had an Intermatic timer that looked like this:
    At the new house I have a Woods 59101R timer that looks like this, except it's in an enclosure rated for all weather:
    After using the Woods for a few days, I prefer this style of timer. It's a bit easier to set the time - with the Intermatic to get the set screw tight enough I needed pliers, so changing it meant tools. I've also discovered with the Woods that if I turn it on manually, when its off, it will run until the next interval and get turned off automatically. Handy when adding chemicals like this morning. I added pH increasr then left the house knowing the timer would turn the pump off.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pool Pump Timers
    Looks like it might be directly compatible/replaceable. Yes, it is...
    Woods timers and manuals:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Thanks for the info, it does look a bit easier to operate for sure. Yes, the timer dogs have bit me a few times over the years getting loose. Lotta dog puns there. The Intermatic will also shut off at the end of the next cycle when manually turned on.
    Jul 2007
    Hillsborough, NC
    525
    Quote Originally Posted by bobodaclown View Post
    I didn't even think about that. Yeah, it is replaceable. The timer just sits in line on the circuit. Wire it so it switches the hot lead. I wired mine to control a duplex receptacle. The pump and the SWG are both plugged into this receptacle.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Quote Originally Posted by pooldv View Post
    I keep a pair of hemostats in the box at the ready to loosen or tighten those timer trigger things.
    DFW, TX
    24,485
    As if we all have a hemathingy sitting around waiting to tighten up a timer thingy!
    Jan 2012
    7,338
    LOL, you just let me know and I'll send ya pair
    Jul 2007
    Hillsborough, NC
    525
    I may have spoken too soon on this timer. This is the 2nd day that it hasn't turned on when it was supposed to. I had to turn it on. My working theory right now is this is also the second day that I turned the pump on manually via the switch on the timer during the off period. I turned it back off after letting it run for a while so I'm not sure why that would make a difference. Yesterday I was getting some more CYA into the water, today I was backwashing. I will not touch anything tomorrow and see if the timer turns the pump on like it's supposed to. The Intermatic I could do whatever I wanted and it would turn the pump on like it's supposed to.
    May 2015
    Ten Mile, TN
    74
    My timer stopped working (only 18 months old)..but when I read the above.....I wasn't sure what you meant. I had manually turned on the pump with the switch in the timer and after that it wasn't working. The manual for the timer says the manual switch doesn't affect the cycle. But is it possible, my timer isn't broken..? Come to think of it...it was off for more than a day, so it should have reset after I put it back in manual and ran 24 hours.
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
