Thread: Ok to put rain water into pool?
    May 2009
    Seminole, FL
    71
    Got some big barrels my wife uses to collect rain water for watering plants and such - But she doesn't use nearly as much as they hold. Is it OK to put some of the water into the pool to keep it full? I heard it may drop the pH and such but are there any other downsides? Obviously it rains into the pool so it can't be THAT bad..
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Ok to put rain water into pool?
    I would say go for it....just be sure to rebalance your water chemistry after the added water has been recirculated for 30 mins
    Jan 2009
    Cupertino, CA
    1,966
    Just for grins I tested my rainwater last winter. pH was low (read as 6.8, hard to say what it was really), TA and CH were zero.
    --paulr
    BBB "Intermediate Swimmer"
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    Like paulr I also couldn't resist using my kit on rainwater and found the pH to be off scale low. Did some reading and found that ""pristine" rainwater is like 5.6; lower in polluted areas. But my experience says it doesn't matter.
    Over the past two weeks I've gotten about 4 inches rise in the pool due to rain, which is about 7% of my total volume. The pH and TA haven't changed measurably.
    I'm sure one of the chem experts could explain it properly, but I think the key point is that the pool is a buffered system, so the pH change is much smaller than simple dilution would suggest.
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    The TA level of rainwater is extremely low. Because of that the pool water, which has a much higher TA level, influences the final PH far more than the rain water does.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    You might have some algae in rain water that's been sitting in a barrel but heck, we know how to deal with algae, right? I'd use it and then rebalance the water.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
