Thread: Damp spot at deep end of gunite every morning. Normal?
    Jun 2016
    Houston TX
    48
    Hi All,
    Gunite was poured for our new pool last week and I have been religiously watering it twice a day for the last 6-7 days. It has been hot here lately and the gunite gets pretty dry during the day. However, when I go out to water it first thing in the morning, there's a damp spot in the bottom at the deep end (where the drain sits). No standing water, but a damp circle about 8-10 feet in diameter. It dries up during the day as the sun hits it.
    Is this normal? is this from groundwater seeping up? or should I be worried? Just want to make sure there isn't a problem with the gunite.
    Thanks.
    G
    jdoty1977's Avatar
    May 2016
    Little Elm TX
    38
    Re: Damp spot at deep end of gunite every morning. Normal?
    Should be fine. The gunite needs to allow ground-water into it so your shell does not lift/float. Movement can cause cracking or worse. I had about 6 inches of water in the deep end at all times due to ground water seeping. Congrats on the new pool. Hopefully this crazy weather will give you a fast build from here on.
    2016 Build: 20x30 15K Gal-IG Gunite, #4 Steel Tanning Ledge, Bubbler, Flagstone Coping, Stamped Concrete Deck, Jump Rock, Rock Waterfall, CLI Majestic Isle Pebble Finish, 3 Multi-Color LED lights, Ozone-DEL Eclipse 10, Empty Inline Tab Feeder, 2 HP Jandy Pro Series ePump with SVRS, 2 Skimmers, 6 Returns, 2 drains, 1 Cleaner Return, Jandy CV Filter 460 SF, Dolphin Nautilus+, iAqualink RS Automation, Borates, Test Kit Taylor k2006
    Jul 2015
    Central Valley CA
    1,107
    Totally normal, every time you wet the shell the water that goes down to the deep end will go through the hydro-static valve and dampen the earth below so it stands to reason that part will stay damp as the gunite wicks the moisture back up over time. It is also normal to have several inches to over a foot of standing water in the deep end there is almost no such thing as too much water when you are wetting.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Houston TX
    48
    Thanks for the quick response. Good to know that this is normal!
    We're looking forward to the pool being completed and being able to swim in it!!
