Become a TFP Supporter Pool School
Thread: Replacement Caps
    Replacement Caps
    I purchased a house that already has an above ground pool. The pool has a new liner but needs new caps. I have no idea what company made the pool, therefore, I am having a hard time buying replacement caps. Does anyone have any idea if there is a cap that is universal or how I can purchase new ones?
    Thanks!
    Ohio
    87
    Re: Replacement Caps
    Hello Shaylee and welcome to TFP!
    It is kind of hard to figure out your question from your post but I will take a guess and try to help you a little. You stated that the pool has a new liner, what style of liner is it, overlap, bead, or what? A picture would help greatly to help figure out the part(s) you are talking about. If it is an overlap liner, are you talking about the "caps" that go over the edge of the pool wall to hold the liner in place at the top of the wall? If it is an overlap liner that is the coping and is plastic pieces approximately 3 or 4 feet long and just snaps over the edge of the wall. It is pretty universal and can be found online or at most pool stores that sell replacement liners.
    Are are you talking abouth the metal or resin top rail that goes around the pool edge?
    We really need more information and like I said a pic would be very helpful.
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    As noted above, a picture might be the only way to identify what you need. If it's the tops for the uprights, it will be critical to find the manufacturer. A pic will be essential for that.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    I have the same question. I need to replace the cap/railing around the top of the walls of the pool. In my case it is metal. The pool is old, I bought the house with it. I have no documentation or can find any manufacturer information on the outside of the pool - is there a common place to look for this? I have replaced the lining and the sides are in good condition. A replacement generic vinyl cap/railing would do the trick if there is such a thing? Any ideas? Thanks.
    24ft. AG, 13,500 Gallons
    Sand Filter
    Hayward Max Flow 1.5 hp
    "Trying BBB"
    Jun 2008
    Port Neches, Tx.
    144
    Have ya'll looked under one of the caps currently on the pool for a name?
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    Hello all,
    Newbie poster here although I've been a fan for quite a while!
    I am also in need of some pool caps and have been trying to get them replaced for two to three years now with no luck. I have a 27' round Vogue Flair pool, installed about 7 years ago. We ended up with wind damage from the winter, the wind got under the cover and lifted it enough to destroy 8 of our pool caps. These are the caps that link the rails together at each column the whole way around the pool. I have contacted vogue directly with no luck, they will not deal with pool owners directly. I have emailed every vogue pool dealer within a two to three hr radius from our home via email with no luck. We've ended up getting them shipped through a dealer twice (two different ones) both times they did not fit. (now were stuck with them and they cost us $80) The part/manufacturers # is the same everytime a dealer speaks with them but the part does not fit. It has not seemed to compromise the stability of the pool but it looks really bad and does hurt if you happen to get too close and scrape yourself. I'm with the two previous posters....wondering if there is some sort of generic cap somewhere or maybe a pool salvage somewhere that I might be able to find them at.......Any help would be appreciated. I can send pictures if needed.
    Corrinna
    29K IG vinyl, Sand filter, 3/4 HP pump, and newly installed SWG.
