Thread: Intex sand filter/lateral lines Help!
    Jun 2016
    Kansas
    5
    I "accidentally" pulled my lateral lines up out of the sand and need to dump the sand in order to properly place the lines again. Anyone know if it's possible to remove the center tube from the valve to make it easier to dump? Or even if it's possible to remove the lateral lines from the center tube? Having the entire valve assembly still attached is making it next to impossible for me to dump this sand out.
    Thanks in advance!
    Kristi, Kansas
    15,000 gal intex, above ground
    Sand filter, SWG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex sand filter/lateral lines Help!
    you should be able to use a shop vac and vacuum the sand out then fix and replace the sand
    Jun 2016
    Kansas
    5
    Quote Originally Posted by cowboycasey View Post
    We were able to get it disconnected. Thanks for the response!
    Kristi, Kansas
    Sand filter, SWG
