Thread: Seasonal/Temporary Pool - First Timer
    Jul 2016
    British Columbia
    6
    Hello all,
    This is my first post and I already know I'm not following the protocols by entering my detailed equipment information in the signature line but I'm hoping someone can advise me on this likely simple question. I am attempting to following the guidelines for a 'Seasonal/Temporary Pool' and it states that we only need the two way test kit (ph and fc), but then further on the instructions require that we know our CYA levels as well. How do I test the CYA level with only the two way test kit?
    Thanks for your help.
    Kris
    (above ground 12' x 39" BestWay Steel Pro Frame (Canadian Tire) round vinyl pool with pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Seasonal/Temporary Pool - First Timer
    Welcome to TFP!
    You will know what your CYA level is because you just added it. So, if you add 30 ppm then that is what it is. There is no CYA in tap water.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,265
    Welcome to TFP! Good to have you here
    Good question. Along with what pooldv explained above, it may help to understand that CYA is not consumed. It stays in the water and doesn't wear off the way chlorine does.
    Let us know if you have any other questions or would like us to walk you through anything.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2016
    British Columbia
    6
    Hi ... thank you both so much ... I figured it was an easy one . I have to test my levels again this morning and for sure will have more questions for you later as so far it's not going very well. Thanks again !!!
