Thread: SWG No Power (Aquarite)
    kenmacboston's Avatar
    Apr 2012
    Haverhill, MA
    30
    I have no power at all to my unit. Replaced the current limiter 2 months ago, and the unit worked until last week. Checked for burned out components but do not see anything that looks burned. Is there a procedure to check voltage at various locations to confirm which board is bad?
    Ken Macumber
    18,000 Gunite, salt system, 250K BTU Hayward Heater, Waterfall, Fiber Optic Perimeter Lighting.
    20 yrs pool veteran
    Re: SWG No Power (Aquarite)
    Check for power where the power wires connect to the box.
    Can you post the diagnostics?
    Support the site
    Apr 2012
    Haverhill, MA
    30
    I've checked for power at the connections to the main board and I have power at the source (where the wires are connected onto the main board). Nothing beyond that on the board. I have also looked for breaks on the board itself (solder or plating on the board) and I do not see any irregularities. I have not checked the transformer yet (I need to confirm the voltage going out to the inline unit (what is the voltage going to the generator itself?) Thank you.
    Ken Macumber
    20 yrs pool veteran
    Jun 2011
    Long Beach, CA
    2,781
    InyoPools has a troubleshooting guide, https://images.inyopools.com/cloud/d...ting-guide.pdf.
    Apr 2012
    Haverhill, MA
    30
    This is exactly what I am looking for, will check voltage, etc, before buying what I need. Thank you!
    Ken Macumber
    20 yrs pool veteran
