Thread: Can't get it clear
    May 2014
    Pasco, WA
    41
    Can't get it clear
    I've been using the TFP method on my above ground salt water pool for the last 3 years. The first 2 years it was easy. I stayed on top of it and never had any problems. This year I am struggling. Water has been slightly cloudy since opening and I can not get it clear. Lately it has taken on a slight green tint.
    The mystery is that my numbers have always been solid/spot on. Here they are from my last test:
    FC: 5.5
    CC: .5
    PH: 7.6
    TA: 90
    CH: 80
    CYA: 60
    Pool stats:
    Above Ground
    Vinyl Liner
    17000 Gallons
    Pump run time: 12 hours at 100% generation
    I haven't done a slam because my numbers have been right on. But I'm thinking it's my only option at this point. I wanted to come to the professionals first and see if I was missing anything. Could the sand in my filter need replacing (it's only 3 years old)?
    Any suggestions?
    Thanks.
    18k gal, AG, Sand filter, Aqua Trol SWG, Installed 5/2014
    Jun 2014
    15,178
    Re: Can't get it clear
    Definitely SLAM, the sooner the better. You see green/tinted water, hit it now. One problem I suspect may have contributed to the issue is your CYA is a bit low for a SWG pool. Not a lot, but perhaps just enough to where your SWG is struggling to maintain that required FC range. So once you complete the SLAM, consider raising your CYA to a minimum of 70 and see if that helps you maintain FC a little better.
    As for the sand, it should still be fine, although a deep cleaning might not be a bad idea: Deep Cleaning a Sand Filter
    Hope that helps.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    Correct me if I'm wrong here, but for a salt water system, aren't your TA, and CYA levels a bit low, which would mean that so is your FC?
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Doing an Overnight Chlorine Loss Test will always give you an answer on whether to SLAM or not.
