Results 1 to 7 of 7
Thread: Time to replace my T cell 9? Is a generic model just as good?
    Oct 2015
    Lynchburg, VA
    23
    My instant salinity reading on the control panel is reading 1000 ppm less than the actual salt level (confirmed by test strip and pool store testing), so I think it's time to replace my T-cell-9.
    I tried re-calibrating the salt reading following the instructions on this video but it's still reading 2000 ppm when the tests say 3100.
    The Hayward brand retails at $460, but I've seen prices online as low as $330. Then there's a compatible generic model (CaliMar) that is just under $300. Does anyone have any experience with the generic models?
    IG 26k gal, vinyl liner, Hayward S220T sand filter, Hayward SP2607X10 pump with Century UST1102 motor (single speed)
    Goldline AquaRite swg with Tcell-9
    TF-100 test kit
    located in Central Virginia
    Re: Time to replace my T cell 9? Is a generic model just as good?
    Make sure that the T-Cell setting is correct. If it’s set for a T-15. Then the reading will be off. Also, it’s usually better to go with a T-15 cell in most cases.
    Support the site
    Oct 2015
    Lynchburg, VA
    23
    I have checked the diagnostics and yes, it is set for T-9. That's the unit that was here when I bought this house last year.
    TF-100 test kit
    Jun 2011
    Long Beach, CA
    2,790
    Your pool will be better off with the T-15 as it can produce a lot more chlorine in a day compared to the T-9.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The T-15 is a much better value. It doesn't cost much more. In fact I think you can find one on Amazon for about $450. Just don't buy the T-15w, it only has a one year warranty vs the three year on the regular t-15. Do not buy a generic. Way too many reports of problems and short life. My first T-15 lasted well over seven years. $450/7= less than $65 per year chlorine cost for a 19k pool that's open year round.
    chiefwej
    Jul 2015
    OV, CA
    65
    I agree go with the higher capacity T-15, its not that much more. Before you order a T-15 I would double check that your controller will support it. Some of the earlier ones were locked into the Tcell that was sold with it (like mine will only run with a t-15 from what I've been able to gather). so make sure the setting can be changed to a T-15.
    20K IG gunite with attached spa, dark plaster and lava rock waterfall, very 90's. Pool equip refit in 2005 with all Sta-Rite cartridge filter, pump, and heater; Polaris sweep; Goldline Controller(Hayward) with T-Cell-15 SWG
    Oct 2015
    Lynchburg, VA
    23
    I checked my controller, and yes, I can set it for any of the cells. Thanks for the recommendations, all!
    TF-100 test kit
