Thread: Inefficient backwash
    Jul 2015
    Chester
    3
    This is the first time I've ever had a question I couldn't find an answer for on the site. I started with new sand this year. I should note that we have high iron well water, however, once it oxidizes it filters out easily.
    No problems with the (brand new) pump/filter for the last month. Excessive chlorine loss over the last few days pointed to algae, and so began the slam. I've noticed small amounts of sand under the return before, but today there was an unusual amount. So I sucked it and some bigger debris up and watched the return spit it back out.
    Tore the filter down for inspection, and found....
    The sand was so filthy I'm surprised it hadn't become sentient. The tiny slits in the laterals (?) Were chock full of debris, but not broken. I backwash and rinse regularly, but to look at this mess you'd never know it.
    Is there an issue with the pump pressure not being high enough to flush out all of the junk in the sand? Are the sand particles too big for the pump? Or am I overlooking a simple, common sense detail per usual?
    Intex 10" filter/pump combo
    #20 sand
    Thank you in advance!
    22,553
    Re: Inefficient backwash
    Sand filters require a certain amount of flow when backwashing to ensure a good cleaning of the sand.
    One of the biggest problems with the Intex pumps is that they are undersized for most of the applications they're in.
    Sounds like you are probably going to have to deep clean the filter on a more regular basis than most other people. The good news is that now you know that and can adjust for it. Another thing you can do is to backwash for a longer time than you think it needs when you do backwash it.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,279
    Welcome to TFP! Good to have you here
    Along with advice above, just wondering... does the filter have a rinse setting that you use after backwashing? When I first started off I wasn't rinsing long enough. I find I need to rinse for about 1.5 minutes to avoid cloudiness back in the pool after backwashing.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2015
    Chester
    3
    Quote Originally Posted by needsajet View Post
    Thank you! And yes, I rinse after backwashing but will try letting it run longer for sure.
    Thanks again!
    Quote Originally Posted by Bama Rambler View Post
    Luckily I found the sticky yesterday for deep cleaning the sand without having to take it all out. It was super helpful
